I got a nice piece of granite for cheap, and I am almost ready to mount it on the new vessel is actually smaller than the dimensions!
See below:
picture of the leftover when placing it on top with equal space on the sides No space in front, only on the rear Whole hole view..
Any suggestions? Ideally I want to find a sink that will fully cover the hole, but so far my searches on Amazon.ca (I am in Canada) don't look promising - they are mostly curved and apparently just like the one in pictures, the dimensions mentioned are of the top part, not of the base! I am not sure if the largest one I found so far would cover it fully in the base...
Edit:To explain why top mount and undermount is not suitable: the vanity its supposed to mount on(unfinished, unpainted yet): enter image description here
18
  • You are trying to put a square peg in an ovel hole. Look for oval bathroom sinks.
    – Jeff Cates
    Feb 24, 2019 at 3:41
    The one I linked is a dual, meaning it can mount from above or below. You need to look for an oval top mount sink of the 18.7" size or as close to that as you can get. Then weed out the ones that won't fit the depth. Or, search for an oval top mount 19" x 14" and see what comes the closest to it. As for plugging the faucet holes, when you buy your faucet, you can get ones with a 3 hole setup or a plte to cover 2 of the 3 holes, or use a stainess steel hole black that you press it, put some caulk around the hole, and pop them in.
    – Jeff Cates
    Feb 24, 2019 at 3:54
    I suppose if you could find a shop that throws out their granite scraps, like if they cut a hole in a counter top, they sometimes toss the cut piece...find one close to the size,, bigger and you can grind it to fit, then use silicone to attach the "fill" piece to the counter top, and use a few boards on the bottom to support the fill piece and the weight of the vessel including water. Instead of boards, you could use metal brackets screwed into the granite from below.
    – Jeff Cates
    Feb 24, 2019 at 4:36
Find a sink that you like with a slightly larger dimension and cut the granite to fit. With the right tools it's very easy and obviously you need to be careful. The only expensive item you need is a grinder. The others are a big sponge, bucket, diamond grinder wheel and water. It's a bit messy so I'd do it outside.
1 get your sink.
2 confirm that it is suitable.
3 measure and mark by scratching in the surface of the granite
4 on a flat surface shimed up for blade clearance, grinder in hand and sponge in the other. Wet soak the sponge and use it to keep the blade wet as you grind. (if you get help a hose will work)
Cut in from the opening to the line all around then cut on the line to knock off the pieces.
5 check for fit, trim if necessary and clean up.
I've done this before and it took about 20 minutes to do the actual cutting. I'm sure you can find videos online.
  • Hi Joe! I really appreciate the detailed post and effort made, but have you seen my edit as of 20 minutes ago at the bottom, showing the vanity? It has drawers, I cant do top mount or undermount, it has to be a vessel mount. Unless I misunderstand, and your rectangular suggested cuts are for vessel mount somehow? Feb 24, 2019 at 4:24
  • Oh crap, I somehow missed the vessel part and didn't see the picture of the vanity. The shape doesn't matter, you can trim a little or a lot. if you get a vessel mount that is a close fit you can use this method but you would have to be very careful to get a clean line with a slight bevel. A nice caulk job would hide any imperfections and support the sink. Also I've been on jobs where pros come in and do the service for the customer. An experienced guy can make it look like a factory cut.
    – Joe Fala
    Feb 24, 2019 at 4:33
  • Some vessel sinks are sort of flat on the bottom around the edge. That way you wouldn't have to be so careful with the cut.
    – Joe Fala
    Feb 24, 2019 at 4:37
  • I dont quite visualize what you mean... at this point I am going to first try and find a larger vessel that would fully cover the hole, unless you could point me to an example of your meaning? The hole size is approximately 47.5cm/18.7" width (left to right) and 36.5cm depth (14.3"). Feb 24, 2019 at 5:11
You may be trying to solve an X-Y type problem. Have you tried going to a granite shop and pricing a suitable sized slab of granite top that does not have a hole? You may find that the high prices charged for some special sink that can cover the hole is reasonably offset by the cost of a more reasonably priced sink.
I had a similar problem for a shop sink in my lab and came up with a odd solution, I used the sink I had but used spacers to raise it about an inch above the counter top, then I cut a 2 part plastic adapter fitting that made a sloped connection between the two. about a 30 degree slope connecting the sink to the counter. I used plastic because that is what I could shape the easiest, but you may be able to use wood, metal, granite, or even putty. Scrap granite from trimming the countertop was my second choice. Failing that you might have to go with a large raised vessel sink.
