This is related to a question I asked earlier regarding my deck footings.
I had a pool deck built last fall. The footings are 4' deep and 12" diameter. There are metal post brackets attached to the concrete, and the PT 4x4s are attached to those brackets.
The builder only poured the concrete to about 6" below grade. So now my posts are buried about 6" below grade. Well, not exactly buried, as the footings were dug out and left as holes. Those holes filled up with rain and are now my posts are sitting in blocks of ice. I assume I should fill the holes with something in ther spring when the ground thaws.
Is there anything I can do to help my wood posts from rotting? I know I need to regrade the area so water drains away from the footings, but I don't know if it's ok for the bottom of the posts to be buried. And if so, what material do i use to fill in the footing holes (sand, crushed stone, gravel, etc)? Should i coat the posts with some type of rubberized sealant to keeo away water?
I attached a photo (from the fall, it is all frozen now) for reference. Thank you!
