I had an above ground pool installed and a deck built around it early last fall. The way the builder built the deck footings was to pour 4' of concrete 12" in diameter, then attach metal post brackets to the concrete where the 4x4s sit. This would be fine if the concrete came up to grade (grass level) but the builder poured the concrete so it comes up to about 6" below grade. So, when it rains, the footings fill up with rain. Right now, about half my footings are filled with ice from pooled water that never drained (so the bottom 6" of the 4x4 is in ice). There is also a drainage problem in the area. Anytime we have a torrential rainfall, the ground does not drain fast enough, and I have a pool of water surrounding all my deck footings.
I need to do something in the spring when the ground thaws, but I'm not sure what. I think i need to regrade the whole area under the deck (about 350 sq ft) with a small shovel since the deck is only 4' tall, and bring "grade" level down to the height of the concrete. That way water won't pool in the area around the wood 4x4s. But, that is a huge amount of dirt to move by hand... maybe i could dig trenches under the deck to guide water away from the footings to another area?
I've attached some photos for reference. This winter I've just been shoveling snow away from the deck, and using a submersible pump to evacuate water on warm days when the ice melts a bit. It's a mess.
