Table saw blades spins fast, but stops on contact with wood whilst motor keeps running so cant saw wood Its Rexon Model RM130, 1.6kW, RPM 4800 had not been used for some years I have sharpened the blade. Your advise willbe most helpful
1Hello, and welcome to Home Improvement. Is this saw belt drive, geared, or direct drive? Are you sure you have the blade on tightly? – Daniel Griscom Feb 19 '19 at 13:28
Add a comment
Either the blade is slipping on the arbor or the belt is slipping on a pulley. If the former, tighten it. If the latter, tighten it.
2Small adder: If the arbor is tight on the blade and the belt seems fairly tight, replace the belt. As they age the get slick and won't grab the pulley. – Paul Logan Feb 19 '19 at 23:43
