I'm doing a kitchen renovation and moving the location of the sink so that the plumbing stub-outs (supply and drain) need to exit the wall one stud-bay over. I'm also replacing the old galvanized pipe existing as the vent stack in the process.
My plan was to notch out the stud (not load bearing) between the two bays,and run a short horizontal section to a 90 degree elbow, exiting the wall at the new sink location.
Are there any issues (code or practically speaking) with the 90 degree turn in the horizontal at the sink drain?
See attached photo. My proposed modification is drawn poorly in red :).
