Is it ok to put polyurethane as a protective coating on a marble countertop?
I want to protect the marble from scratches and staining by foods and other kitchen hazards.
    I have never used poly but have used sealers made for granite ,marble and concrete in the past that protected the surface and added a little shine.
    Commented Feb 13, 2019 at 22:40
  • Poly will scratch and flake off, looking worse than a few scratches in the stone. The marble is less likely to scratch as is why it is used as a cutting board surface. A sealer would be good to stop staining, however, bleach or a marble cleaner can be used to remove stains. Best to stay away from poly for this purpose.
    – Jeff Cates
    Commented Feb 24, 2019 at 4:39
