I want to install fans in a covered deck. The room is timber beams and trying to hide wiring best I can.
What options do I have, if I use UF-B can I cover with wiremold raceway (which would be merely cosmetic b/c I believe UF-B does not need to be in raceway/conduit.
If I use THWN, I don’t think wiremold would be adequate, and I think it can only be used in dry locations.
Any options for a low profile approved conduit for damp locations? Or is UF-B in wiremold a good option. I would like to cover the raceway with trim.
Also I assume regardless of wire/conduit option, I need weather proof fan boxes? If not using conduit what type of fitting do you use on the weather proof box?
