First time installing kitchen cabinets. Uppers went it fine, no trouble at all. With the base cabinets, though, I have one wall that is out of square about 1.5 inches in 12 feet.
Should I just be making them level for the countertop and plumb, as tight to the wall as possible, or should the entire run of cabinets along that wall be perfectly square to the perpendicular row? Said differently, should I be shimming them out from the wall at each cabinet so that when I get to the last cabinet I have 1.5 inches of shims behind it?
Wouldn't that make the countertop look a little funny if it was 1.5 wider at one end than the other, especially if it's only 12 feet?
Thanks all.
