I can't afford a new door so how can I repair it.
How much will it cost me to install a new door
  • Hello, and welcome to Home Improvement. You may want to replace your roommate when you replace your door. That said, cost estimates are off-topic here. – Daniel Griscom Feb 12 '19 at 0:13
In that condition, unless you get a steel cover plate to repair it, it's time to replace the door. Look for this item:
https://s3-media1.fl.yelpcdn.com/bphoto/RrkHH45lZUiGHlXLzZgy7w/o.jpg
  • I agree as the tools to repair that much damage can get fairly involved. – Ed Beal Feb 12 '19 at 0:21
    I agree as well and most attempted repairs will not be as strong as the original wood side rail of the door. – Michael Karas Feb 12 '19 at 2:11
Put little wooden screw or small nails/studs into the wooden door and apply the m-seal on it with mixture of wood powder, and colour it with same paint.
Note: Make sure m-seal and wooden mixture not go inside the latch/lock mechanism
  • Hello, and welcome to Home Improvement? What's "m-seal"? (Please edit the info into your answer; thanks.) – Daniel Griscom Feb 12 '19 at 13:49
