I need to accurately drill multiple holes in steel pipe (1.25-2" diameter, 65-100 mil wall thickness, about 10ft long). I need to drill a half-dozen or so evenly-spaced aligned pairs of holes all the way through the pipe. So the two holes in each pair need to be diametrically opposite. And the pairs need to be radially-aligned - I'm not sure how best to describe this: maybe, if a line is drawn through each pair of holes, those lines should all be parallel (to each other).
Is it possible to do this with reasonable accuracy using home tools, or is a machine shop necessary (e.g. a milling machine) ? How ?
P.S. For background: I want to extend the height of a wood railing (it consists of multiple 2x2 balusters with a 2x6 board at the top). I plan to do this by screwing 3/8 x 10" hanger bolts into the top of the 2x6. Then attach the steel pipe to the machine-threaded top of the hanger bolts, with acorn nuts at the top and hex nuts underneath the steel pipe. This is my solution to: extend height of wooden railing. Once the pipe is drilled, I can then use it as a jig for drilling the pilot holes in top of the 2x6 (for the tapered-thread end of the hanger bolts). Perhaps I should consider wooden dowel instead of steel pipe; easier to drill, and cheaper (when I screw up).
13
    Sounds like you need at least a drill press. Even the smaller ones should handle a 2" pipe. Are you ok with that? (less than $100)
    – JPhi1618
    Feb 11, 2019 at 20:04
  • I'd rather figure out how to do it without; OTOH it's not clear that's enough. It should be easy enough to make diametrically-opposite marks on one end of the pipe; and a pair at the other end. If I could just get those two pairs aligned with each other, then I could pop two chalk lines down the length of the pipe. Feb 11, 2019 at 20:07
  • You'd need some kind of jig, then, to hold the bit perpendicular to the pipe face. The issue is that you have nothing to guide the bit inside the pipe, so if your jig has any wiggle to it (which it probably will), you could end up with less-than-perfect holes.
    – Chris M.
    Feb 11, 2019 at 20:11
  • When the pipe is laying on the ground, the contact patch with the ground is a straight line. My concern is getting the hole exactly straight through the pipe. You could make some home made jigs, but at some point your time and the accuracy of the project is worth more than a $75 drill press that you could sell to recoup some expense later.
    – JPhi1618
    Feb 11, 2019 at 20:12
    some pipes have printing on them from the manufacturer .... the printing could be used as a straight line ....... also the pipe may have a seam down its length that could be used as a straight line
    – jsotola
    Feb 12, 2019 at 3:18
Yea, I think you'll at least need a drill press. But it really depends on exactly how accurate you need it.
In any case, I'd work it like this:
  1. clamp a straight piece of lumber to a flat table. Should be at least as long as the span between the furthest holes. Lumber must be <= half the outside diameter of the pipe. Close to half the diameter is ideal.
  2. Clamp the pipe against the edge of the lumber. Draw a line down the length of the pipe with a fine tip sharpie
  3. Get a pipe jig you can clamp to your drill press table. Center it under the bit by lowering the chuck & bit down into the jig as you bolt it down.
drill press pipe jig
  1. Make a reference mark on the edge of the where it contacts the pipe.
  2. Lay the pipe in the jig, adjust the the proper horizontal position, and align the line on the pipe with the mark on the jig.
  3. Drill!
You could do this with the jig and a hand drill. The problems are getting the center of the pipe for the initial hole, and then keeping the drill straight enough when you punch through the other side. It depends on how accurate you need it.
  • I don't need it super accurate. I still think I'm better off drilling the two holes separately. Then I don't need to worry about the bit being that straight. I just need to somehow make two diametrically-opposite lines with their ends at the same point on the circumference. Feb 11, 2019 at 20:39
  • Drilling from both sides opens up alot of room for error/inaccuracy. Maybe you could share what you're doing with this. That would help us understand your accuracy requirement. Anyway, if you want exactly opposite lines down the length of the pipe, strike the first line as I described in #2 above. Then use a center finding jig like this: amazon.com/Robert-Larson-800-2875-Plastic-Center/dp/B000CD1T0A to mark the other side. Then repeat #2 with the new mark aligned with the edge of the lumber. Feb 11, 2019 at 20:45
  • I have edited the OP question, adding a PS to describe my application. Feb 11, 2019 at 22:09
Looks like this project has two main issues - getting all the through-holes in the same plane on the pipe, and making a straight hole all the way through a pipe.
To draw a straight line on the pipe, you can set the 2" pipe on the flat ground (like the floor of a garage) and place a common (straight) 1x4 board next to it. Run a marker along the corner formed by the board touching the pipe and you'll have a straight line.
For drilling the straight holes, you can either buy a drill press (random example) or you can make a jig. The drill press is pretty self explanatory, so here's an idea for a jig.
 Drill bit
  _!_ top plate
 |_!_| bottom plate
 |/ \| - hole for pipe
_|\_/|_ footing
_______
Now, with my amazing artwork out of the way.... You make this structure with some 2x4 lumber and use a steel plate (thin is fine) on the top of the "top plate" and "bottom plate". The total hight of the jig will be about 11". The square at the bottom should be just big enough for the pipe to fit in to keep it centered. Get a 12" long drill bit and drill through the jig as straight as possible measuring as much as you can. This pilot hole will make or break your jig. The steel sheets/plates will help keep the bit centered over the long run but are optional if you don't have many holes to drill (the wood of the jig will waller out after repeated use). If you can get a perfectly straight hole, you should be good to go! insert the pipe and get to drilling.
  • Not quite following. But I think it'd be easier to drill the two diametrically-opposite holes separately, if I could just mark it properly. You describe a good way to get a line down one side of the pipe (in your 2nd paragraph, above). Then at each end, make two marks diametrically opposite the two ends of that 1st line; use those marks to draw the 2nd line. Feb 11, 2019 at 20:35
  • Improved the picture a bit? Sorry, it's clear in my head. The issue with having marks on each side of the pipe is still going to be getting each hole straight. Maybe a little angle to each hole won't matter for you, but if you're drilling a 1/4" hole and expecting to push a 1/4" rod through them, they both have to be perfectly straight and aligned. Going at it from both sides would be way too hard in that case.
    – JPhi1618
  • Yeah, I see now. Looks like this will get you one nice straight diametrically-opposite hole-pair. But when you slide the pipe through the jig to where you want the next hole-pair, how do you insure it's at the same point on the circumference ? Using the line you've drawn before ? Feb 11, 2019 at 20:43
  • You would make a mark on the side of the jig in the center (in line with the drill bit) and make sure the line you drew lines up with that center mark.
    – JPhi1618
    Feb 11, 2019 at 20:49
