I was wondering how could I drill a hole directly through my first story ceiling to the second story floor without severely damaging neither floor nor ceiling. If possible, could someone give me detailed advice on what to watch out for and how I would drill it?
New contributor
Andrew Dang is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
put on hold as too broad by isherwood, Daniel Griscom, Tyson, Machavity, mmathis 12 hours ago
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    Too many possibilities here. The answers are quite different for concrete slab vs. wood frame. Sometimes the solution is not to drill at all but run a cable externally along baseboard, down stairs, etc. Need more specifics. – manassehkatz Feb 11 at 2:02
    Yeah, you need to show us your situation and ask a more specific question. The answer varies wildly. – isherwood Feb 11 at 14:39
I have never done this, but this is how I would do it:
First be sure there is no reason to suspect that wiring or plumbing is obstructing the space you want to run the wire through.
Then drill through from one side just into the interior space so if any thing important is there, you won't drill into it. Electricians often use long, flexible drill bits to drill through ceilings and top plates.
Then use a probe (e.g., piece of coat hanger wire or small diameter wooden dowel) to feel in the space for obstructions (better yet use a borescope to visually examine the space).
Work a long drill into the hole you have made until it hits the opposite wall and only then turn on the drill. After this drill goes through the other wall you can use it to pull the wire through, simplifying the task of linking up the two holes. Or go to the other side of the wall and drill exactly where you want the hole and stop immediately after you penetrate into the interior. Use a probe to link up the two holes.
From one side or the other you might have to drill a 2" or so diameter hole to be able to get the wire through. You would then have to plug this hole except where the small wire goes through. I would use a hole saw on a drill. The piece removed by the hole saw could be the basis for a plug.
