(Preface: I have read all of the related, earlier questions I can find... still stumped.)
I added an outlet to a run by cutting (before Outlet A) what I thought I had identified as the line in to Outlet A, and adding a Romex pigtail to the new outlet (Outlet N).
With breaker back ON:
  1. Outlet A is powered and fine.
  2. Outlet N is NOT powered.
  3. Outlets B and C (down run from Outlet A) are NOT powered.
What did I do wrong? Did I add the pigtail to the wrong wire? If the answer is YES, wrong wire, I did my best to ID the line coming into Outlet A; what is the trick I missed?
Additional info: House built in 2003; breakers are identified in box, but IMO oddly organized (example: "kitchen outlets" turns out to include random outlets in living room);
Thank you!
    Pics or it didn't happen. – brhans Feb 11 at 1:19
    a cable contains several wires within a sheath. Each wire is a different color. When a cable is involved, I would not call it a pigtail, I would call it an extension. It would be clearer if you could edit to make sure you are using the appropriate words, you can also add a photo the same way. – Harper Feb 11 at 1:24
  • Can you post photos of the insides of all boxes involved? – ThreePhaseEel Feb 11 at 2:28
  • THANKS to all who kindly suggested clarifying edits and pics; I will get this done later today. – DIYMakesMeHappy Feb 11 at 14:51
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
