I have a water expansion tank (5 gallons) installed on a new water heater (40 gallons) and my houses PSI is at 70-80.
The tank came precharged at 25psi.
I know that I am supposed to match my home water pressure and that of the tanks but I wonder if this does not have to happen immediately.
If I had to do it immediately, do I have to shut down the main and can I pump using an electric pump or do I have to disconnect the plumbing and remove the tank altogether before I can pump it?
