My door is missing the strike plate and its keep opening up when there is a slight draft. So if I align the door it goes into the strike plate without any issues. I believe its a loose screw. So, I tried to remove the screws and reinsert them.
When I did that I have one struck screw and two broken screw heads in a door hinge. 1 I was able to extract. :-(
I tried to extract it with "Tack Life damaged screw extractor".
