I have a honeywell hz432 and just installed a few NEST thermostats with a common wire and they seem to run fine. I added another NEST E thermostat, but this one didn't have a common wire, and when it calls for heat I notice that it seems to be stuck in a loop where it's cycling the system in some way. I see that as soon as the system ignites the burners ready to send heat, it immediately goes into purge mode and then the whole sequence repeats. I put the old thermostat back on and it seems to run fine.
Does this mean my Nest E is incompatible with my system without a common wire? I read somehwhere that I can jump the fan wire into the common somehow if I don't need to control the Fan independently. The other choice is to run an extra wire from the thermostat into my basement through the walls which would be quite a challenge.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
