I have an ethernet cable that goes into house from the outside wall.
What sealant should I look for that will not crack the cable?
I need to keep wind and rain out of the house from the hole.
It has to be compatible with plastic.
Sign up to join this communityI have an ethernet cable that goes into house from the outside wall.
I normally use a paintable silicone but with brick would use clear , silicone is what the cable and satellite company's used on my homes and I use it at work also for sealing small holes.
