During the winter chill here in DC, one of my pex pipes that is not insulated and basically exposed to the elements cracked. I blame the contractors who didn't insulate and finish the job, literally leaving a hole in the drywall where you could see and touch the pipes... outside.
I'm back in town and want to repair the cold water pipe and insulate it, but I am a newbie and I don't know how to do this. Do I just put normal wall insulation (fiberglass) in there? I heard something about a heat coil that automatically turns on when it gets colder?
I have googled a bit and found "Heat Cable for Pipe Freeze Protection" on Amazon which looks both super affordable and simple, but I'm not a plumber and I don't know if this is the recommended option. Any advice would be great!
