Thermostat not working, no battery in unit, NO HEAT!! Help
closed as unclear what you're asking by mmathis, Machavity, Daniel Griscom, ThreePhaseEel, Tyson Feb 10 at 10:14
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • Can you post photos of the wiring at both ends? Also, what make/model is your furnace/air-handler? – ThreePhaseEel Feb 8 at 1:36
  • no battery in unit ... does that mean that you want to know what size battery you should use? – jsotola Feb 8 at 6:32
