Sorry for my OCD, but "it is what it is": I hung a 22 lb. clock with a plastic toggle (drywall), then saw it was too high. I put a new toggle anchor in about 1-1/16" lower (in other words, very very slightly more than an inch, certainly not less-- but very close to an exact inch).
I was shocked that moving it a mere inch lower had such an extreme effect, normally I hang things casually and am satisfied. But the clock gets a very different look from a small change.
As you guessed, I would love to hang it exactly in the middle, but naturally worry about all these holes, drywall not being steel -or even wood.
Can I somehow (using a drill, large bit, brute force, but carefully to minimize collateral impact) remove the old toggles, fill with drydex (or some form of epoxy), and start from scratch with a new hole (and anchor) exactly in the middle where I want it? Or would leaving the toggles in place be structurally stronger for the wall than attempting that "surgery"?
Or is it just a bad idea, too risky, to try to put a new hole/anchor exactly between my earlier attempts that are only an inch apart?
Is there a solution such as trying to reinforce the wall in that area somehow (thin metal plate, eg, which will be invisible anyway)? Or by using an extra hanger placed above, to take on some of the load from an unstressed section, about two inches higher).
Thanks for any tips, clarifying a bit how strong or weak that drywall is, and what it can stand (and weight it can safely hold) in such a situation.
Thanks again, Andrew
