What sealer can I use for upstairs bathroom floor I have ceramic tile and it’s leaking on kitchen ceiling. I want a seal between tile and baseboard.
  • 4
    What is leaking? Fix the leak in the bathroom, or the overflow. Unless designed as a basin from the start, a bathroom floor will not contain water. Feb 7 '19 at 0:10
I imagine you're talking about the bit of splashing that can easily occur, especially when children are coming out of the bath or shower.
Someone happened to mention to me just yesterday his point of view about this. He recommended bathroom caulk. I've seen this in the DIY stores. You can either get a squeeze tube and just squeeze as you go, or get the rigid cylinder that goes into a caulking gun.
After you squeeze it out, you can smooth it out with a damp finger. (You can wear rubber gloves if you wish.)
