Instead of making a table support leg drop down vertically to the floor I wanted to make an angle (45 deg) support.
If I measure "A" from the floor to the table top and measure from wall to the end of table top...
Can I assume that "C" will correctly fit with a 45 deg angle at both ends?
NOTE: I could not get my graphic to make a 45, but I meant a 45 deg cut at both ends of "C".
