I am putting in two drains in my bathroom vanity. The tailpiece is 1 ¼" and the drain outlet is 1 ½". In both drains, the trap is touching the white shelf in the vanity, so I can't lower that without cutting into my new vanity.
I had no problem aligning the first drain and it has been working well. Completed photo:
However, on the second drain, with the trap at 90°, it's about 1.5" away from the tailpiece. Here's where I ended up:
Without the extension:
I'm trying to figure out how to make this work without using one of those flexible tailpieces. I am very much an amateur and got lucky with the first one, so any help is appreciated!
