Model: LG LP1414GXR
The unit was running fine but it appears the plug circuitry overheated and went bad. Is it okay to replace the existing plug by cutting it off at the end and replacing it with a new socket that’s rated the same?
From the pictures I’ve attached you can see the circuitry and wiring. There is a fourth wire (non insulated) in the background and I’m uncertain of its purpose. I haven’t been able to find any information with a plug schematic for this unit. I don’t want to leave it disconnected in case it’s a safety feature.
Is there a plug replacement that someone might be able to recommend. The home improvement stores sell a GFCI plug replacement but it only have 3 terminals. I contacted LG to get a new power cord but it cost $120. Greedy a holes!
Plug
  • Looks like a solenoid. Could that be what the bare wire is powering? I've never seen soldered joints like that before. Is that from the factory? – Chris Taylor Feb 5 '19 at 5:04
  • Yes, it’s factory. I suppose it could be powering it—for what purpose? – wellington Feb 5 '19 at 5:06
  • Not sure. Could it be a built-in thermal disconnect to protect the appliance from overheating? – Chris Taylor Feb 5 '19 at 5:10
  • Try this spec sheet: gscs-b2c.lge.com/downloadFile?fileId=KROWM000577223.pdf – Chris Taylor Feb 5 '19 at 5:21
  • Thanks for the instructions that was helpful in my search for a replacement. I came across this. Might give it a try. – wellington Feb 5 '19 at 11:21
