I have zero experience working on stoves. We have a 3-year-old Whirpool and the right-front burner won't ignite properly.
When I turn the dial for that burner it sparks one or two times and then stops - the burner doesn't light.
If I turn that burner's dial so gas starts and then turn one of the other three burner's dials, the front-right burner lights. [I learned that this works because whenever one igniter sparks, they all spark]
I've watched several videos but I can't determine if I need to replace the spark electrode or the igniter wiring harness. Any suggestions would be greatly appreciated.
I can get it to ignite if I turn one of the other dials
.... this is confusing .... please edit the sentence to make it clearer – jsotola Feb 4 '19 at 19:22
