19
I just moved into a new house and am unable to close my gate because there is something nailed to the ground at the threshold that is sticking up too high for the gate the close. Any idea what this thing is? I'm trying to decide if I just remove it to allow the gate to close or if I need to keep it there and bury it a little deeper.contextclose upproblem
  • Looks vaguely like a plastic drainage ditch but with no top-grate.
    – Criggie
    Commented Feb 5, 2019 at 8:11
5 Answers 5
28
That is called Paver Edging. It is used to keep the pavers tight or to separate one section from the other. It's usually covered to the point that you only see a small strip of it. However, it looks like the installer didn't quite finish the job. I would probably do as you suggested and bury the edging deeper. You could also take up those few bricks that are outside the gate, level that area a little better and place those bricks closer to the edging for a more uniform look and to stabilize that immediate area. enter image description here
    While the ground is soft, you can probably pound it down with a mallet. You might want to get a few more of those stakes if it doesn't want to stay in place.
    – JimmyJames
    Commented Feb 4, 2019 at 15:41
    I would suspect that the ground has heaved through a few freeze / thaw cycles. As mentioned, you can either try to pound it down, or dig it out and secure it again.
    – Gary Bak
    Commented Feb 4, 2019 at 16:56
Your particular brand, SnapEdge is simply too high.
You can find their various installation guides PDFs on the web-site.
But the clearest explanation comes from one of their drawings:
You need to remove the edge, and install it down below the gravel it's next to.
Or you can switch to another product where the edges to "under" the pavers; and are effectively hidden.
Can't upvote or comment at @alephzero's comment... but i'd say he's absolutely right: it was installed upside down. The part that is shown should be down in the dirt to keep a grip and not let the edging move with the seasons (frost heave or heavy rain runoff). The top surface won't be a collection of trip hazards as shown here.
Pull the spikes, turn it over, reinstall, and then finish by covering up the top layer with dirt or mulch or whatever matches.
  • 4
    not that Youtube is a reliable source, but this video seems to be by the company that makes these things and shows them in the orientation that mine are installed - thoughts? youtube.com/watch?v=uYSjHAAP-XQ Commented Feb 4, 2019 at 21:10
  • Interestingly this one shows the flat part UNDER the bricks: olyola.com/install-paver-edging Commented Feb 4, 2019 at 21:12
  • @David Doria, in that first video, I don't think that is the same orientation: Where the spikes are getting driven in looks relatively flat and smooth... I'd assume the fins and built-up spike holes are actually underneath... but as you say, Youtube. :) The second link shows both orientations. I've never seen the first... but I don't see any reason why it wouldn't work... other than needing to have your measurements perfect since you're not pushing it up against already lain bricks... you're leaving a void for the final course. Sounds way harder! Commented Feb 4, 2019 at 21:18
  • @DavidDoria What makes YouTube not a "reliable source"? It's simply a platform where anyone can upload videos. It has a ton of really high quality and more importantly, accurate content. I don't see why YouTube would be any more or less reliable than getting info from anywhere else. It's just... better because you get a video.
    – user91988
    Commented Feb 5, 2019 at 18:55
  • @only_pro Of course, I love it. But I figured I'd get flack from someone here if my argument was "yea but look how they did it in this youtube video" as if that were an authoritative source. Commented Feb 5, 2019 at 19:03
I suspect some klutz nailed it down back to front, and the raised edge is meant to be on the opposite side, along the edge of the bricks outside your property. If that would make your gate shut properly, just turn it round.
A slightly raised edge may be intentional, since it will stop rainwater runoff flowing downhill and ending up where you don't want it.
  • 6
    No, it's in the correct orientation. It's there to edge the bricks on the inside of the property, not the outside. The issue is that it's too high near the hinge side of the gate. It appears to have migrated upwards or inward (or just been installed wrong), probably due to being inadequately secured. The latch side of the gate has a clear cut-out so the gate's vertical support (the thicker portion of the gate) will not be obstructed.
    – Makyen
    Commented Feb 4, 2019 at 16:44
  • It is not installed properly. It is there to finish the edge of the brick patio on the inside of the property. As is, it is currently sitting too high. Once installed under the bricks the edging will just come up to the brick surface, placing it low enough for the gate to swing over it.
    – Arluin
    Commented Feb 4, 2019 at 19:33
  • I think you commented/voted on my answer here; I have edited to support my position conclusively. Commented Nov 22, 2019 at 19:48
The mentioned installation instructions say:
[...] our paver edgings may also be installed up against the paver, with the horizontal leg on the outside, if the installation requires it.
