The left switch in the picture controls the light, while the right switch controls the fan. I'm looking to install a ge smart dimmer switch, while disconnecting the fan switch, but still leaving it the switch on the wall as a dud. Any recommendations on how to make it work based on the pic above?
  • Are you removing said ceiling fan from service? Can you post photos of the inside of the fan box? – ThreePhaseEel Feb 4 '19 at 4:45
  • I'm replacing with a light fixture without a ceiling fan. I have not purchased it yet. Is it possible thaty white wore in the pic is not a neutral? That would steer me away from the switch I have which requires a neutral. In my other installations at home, I have been able to use two black wires, ground and neutral. – Mariel Lako Feb 4 '19 at 11:23
  • Some of the wiring connections on the switches are not visible. – Chris Taylor Feb 4 '19 at 12:22
  • Can you post a photo of the inside of the ceiling fan? – ThreePhaseEel Feb 4 '19 at 12:37
  • It's very likely that you can easily do what you propose. We can tell you how, but you'll have to show us the inside of the fan box, which means it's time to take down the old ceiling fan. At least temporarily. – A. I. Breveleri Feb 4 '19 at 12:51
It looks like the wire wire in your switch box, is used as always hot or switched hot. You don't have neutral in there. I bet your power comes into the ceiling fan first, then to the switches. In this case, no, you can't use the smart switch....without re-doing the wiring at the ceiling and the box. You can do it with what wires you have, but the second switch would not work properly (you plan to remove it from the circuit anyway).
You would need to switch wires in the ceiling so that "power" comes to the switch first, then switched to the fan. With the 3 wires you have, its easy to do.
You will tie all whites together in the fan (new light) box, black on the fan (new light) to red and black from circuit breaker to black to switch (nothing hooked up in the fan box to the black wires(2) except just the two, 1 hot in and 1 hot out). At the switch, you will then have neutral (white), black (hot) and red (switched hot). From there you install the smart switch white(neutral) to neutral, black(hot) to hot and red to load. Best practice then is to use a 2 gang cover that has one side as a cover(blank).
