I am attempting to replace a switched standard electrical outlet with a usb one. The current outlet has one half controlled by a switch and I would like both halves to be always live with the new usb outlet. When I removed the plate and pulled out the outlet I discovered 3 black, 3 white, 1 red, and 1 ground wires. My new usb outlet can only accommodate 2 live, 2 neutral, and the ground.
How do I go about connecting this properly and converting to unswitched? Thanks in advance!
Edit: Adding pictures.
Picture 1: Current outlet with wires attached. Note that in one of the outlets I looked at, the red and black wires going into the back (not underneath the screws) were the opposite of this picture.
Picture 2: Current outlet without wires attached.
Picture 3: Back of the switch.
Picture 4: Back of one of the new USB outlets I have.
Picture 5: Back of the other new USB outlet.
