I have a dead end 3-way switch in a 2-gang box. The switch is fed with a 14/4 cable using black as common, red and blue travellers, and white as a capped neutral per code. I would like to add a standard 2-way switch to this box with 14/2 running to a fixture. I would do this by pigtailing the black/common and white/neutral of the 14/4.
Any issue with this?
    the answer to your question is yes
    – jsotola
    Feb 3, 2019 at 5:01
Wow. You actually have /4.
The answer is it can work, but you may need to flip it. That is to say, right now, the black wire may be switched-hot going to the lamp, so the wires are
switched-hot traveler traveler neutral.
If so, you will need to rearrange other parts of the circuit so the other 3-way is the one with switched-hot and the wires that come here are
always-hot traveler traveler neutral.
Then you can simply tap always-hot and neutral.
Tell whoever fit the /4, well done. Normally this question answers with a "nope, unless you like smart switches".
  • Great. The layout is always-hot, traveler, traveler, neutral, so I should be all set. Thank you for the confirmation! Feb 3, 2019 at 23:02
