I am on county water & have a pressure regulator set 55/60 psi. Had trouble 5 months ago with all faucets leaking commode leaking. I replaced pressure regulator.
I called water company and they were working on lines but not close to my home. I put gauge on faucet and was around 100 psi. My question is when county was bringing water pressure back to speed, could that override my regulator set between 55/60 psi. I
    Did pressure return to 55-60 after you cracked open a water spigot? Does it build back up again? – Harper - Reinstate Monica Feb 3 '19 at 3:28
