Tried to screw through the ceramic or even Grout. Would not penetrate with a pretty decent drill.
    what is your question? – jsotola Feb 2 at 2:11
  • What drill bit were you trying to use? – brhans Feb 2 at 2:25
I have hung several things on tile and brick; I always go through the grout/mortar. It has usually been pretty easy to drill with a masonry bit.
Keyword...masonry or tile drill bit. The proper drill bit is needed for the surface to be drilled.
