I'm building a mobile fence and and have limit space to hold down my poles.
I wanted to know what is heaviest material per cubic inch.
Stone, Brick, Concrete... or What?
This is the limited space I have to work with. 10 inches x 5 inches x 2 inches
  • Granite. But, that which you can work with? Concrete. – Mazura Jan 30 '19 at 1:48
That kind of information is easy to find with google. Here's one of the first that came up for me: http://www.rfcafe.com/references/general/density-building-materials.htm
Concrete - 150 lbs/ft^3
Brick - 120 lbs/ft^3
Crushed stone - 100 lbs/ft^3
Limestone - 171 lbs/ft^3
If you really want some weight, go with cast iron - 450 lbs/ft^3
You're diagram shows 100 in^3 which is 0.058 ft^3
Concrete will be the easiest to work with in this application, but would come to just 8.7 lbs A bit more then a gallon of water (8.3 lbs)
