I just got a high efficiency condensing gas furnace installed. I feel like it was done poorly, but I'm not sure. Some questions I'm wondering about are:
  1. Do furnaces need to be level? It is visibly tilted, but at least it's tilted so the water drain is lower.
  2. Does the vent pipe need to be a certain distance from any windows? Mine is almost touching a window.
  3. Do I need a special thermostat to take advantage of a modulating gas valve? They gave me a thermostat that has 1 or 2 heating stages (1H or 2H). The gas valve has 60 settings (40-100%), but I didn't see any thermostats with more than 4 or 5 stages of heating.
Edit: Furnace model Trane XC95m, thermostat Honeywell T6 Pro wifi
    Model # of the furnace would be helpful as the answer may not be the same for all furnaces. – manassehkatz-Reinstate Monica Jan 29 '19 at 4:49
  • Nathan, welcome. Please take the tour to learn what makes a good question and what you're expected to do with it. You're asking several distinct questions here that should be separated. – isherwood Jan 29 '19 at 16:42
It sounds like a basic setup. I will set high efficiency furnaces at a slight angle to help drainage of the condensate. Some systems have pans inside that are already sloped in that case they can be level. The vent and supplies can even touch walls and Windows, when retro fitting from an open combustion to closed where new supply and exhaust vents are required it can be difficult to make things look nice but they need to have the correct slope to drain condensate back or there will be problems later. As far as thermostats they should have offered you different models, the more bells and whistles in a thermostat the more they cost. If the job was a contract price you probably got a low to mid level thermostat. To answer your question did you get a bad job? Not from the questions you are asking? If the duct work is sealed and the condensate drains properly are the things I see when there is below standard work.
  • Thanks Ed, that makes me feel better. Sounds like the install is fine then. – Nathan Tomlin Jan 29 '19 at 16:22
  • I believe it sounds ok photos are always helpful but even then it can look sketchy because it was a retrofit and be a really good job. I have found jobs that looked ok but we're not properly sealed from the trunk ducts to the furnace (big leaks). So with your concerns listed it sounds ok. – Ed Beal Jan 29 '19 at 16:27
