ELBOW PIPE CONNECTOR IS CRACKEDSUMP PUMP DISCHARGE PIPEI just bought a house and now discovered the sump pump extended discharge pipe is broken at the elbow going out the basement wall about 5 feet from floor. Can you help with suggestion to repair? I saw a sump pump discharge hose on a YouTube video; do you think I could change out/replace the 5' pvc pipe for a sump pump discharge hose?
  • Some photos of the problem maybe ... ?
    – brhans
    Jan 28, 2019 at 18:19
  • Thank you I didn't think to take a pic but will take some & post
    – LynieG
    Jan 28, 2019 at 18:21
  • Make sure that you hit the 'edit' link just below your question when you have some pics to add. Don't post them down in the 'answers' section or try here in the comments.
    – brhans
    Jan 28, 2019 at 18:23
  • Hi all - I just uploaded a couple photos of my sump pump discharge pipe that somehow got broken at the elbow connecting to discharge exit
    – LynieG
    Jan 29, 2019 at 14:47
  • Is that a concrete wall which the pipe runs into at the top, or would you be able to open it up a little to get access to a little more of the pipework behind the wall?
    – brhans
    Jan 29, 2019 at 17:51
-1
Cut the pipe in half and put a cuppling on it.
    Hello, and welcome to Home Improvement. We prefer answers with enough detail so that the original poster can understand what to do. Would you add some more info to your answer? Jan 29, 2019 at 22:58
  • I saw a sump pump discharge hose on a YouTube video; do you think I could change out/replace the 5' pvc pipe for a sump pump discharge hose?
    – LynieG
    Jan 31, 2019 at 14:04
