Many years ago, I acquired a pile of tiny, drill-bit-like items that I use to make practically invisible holes in drywall to hang lightweight stuff from. They are indispensible, but I don't know what they're called. I got them from my dad, who in turn had received them from our dentist. They might be used in dentistry, or they might be from said-dentist's hobbies. I'd love to know the origin of this item! enter image description here
  • Welcome to Lifehacks, Tanaya! Unfortunately, the questions on here have to seek a lifehack. For example, "How can I drill nearly-invisible holes in drywall to hang lightweight stuff from?" We don't allow identification questions. Sorry! You may be able to get an answer on Quora.com. – CreatedByBrett Jan 17 '19 at 19:48
    @BrettFromLA is right, this doesn't belong in Lifehacks, but these do look exactly like the things I've seen my dentist using when performing root-canal on me. – Lefty Jan 18 '19 at 7:40
    Yeah, unfortunately Lifehacks was the closest StackExchange site I thought might work. "Medical Sciences" would have been much worse. :) Thanks @Lefty - if that hint doesn't work I'll try Quora. Cheers. – Tanaya Jan 18 '19 at 16:47
    Dental drill bits. Generally only available from dental supply companies and usually only to dentists. Not a Home Depot item. – M.Mat Jan 19 '19 at 19:23
Looks like endodontic files, or root canal tools if you prefer laymans terms.
You can probably find such tools on eBay if you want.
While definitely not the same, you can find similar size bits with a Dremel or similar "Rotary Tool".
Not to be repetitive those are files or broaches , not drill bits. They cut on the flanks by rotation and axial movement . A drill bit (should) only cut on the end. A drill bit does not have an enlarged shank for holding. I have several bits in that size range ; they require a collet to hold them. I never found a use for them except the larger ones are good to clean carburetor passages.
