Installing a cabinet and upper bookcase on wall where outlet exists (but is never used). Wanted to fish a line from top of bookcase (thru wall) down to new wall switch and on to outlet box to use that to power a couple of small decorative lights being mounted on headboard of new bookshelves. It sounds straight forward but wanted to make sure I wasn’t getting into any code issues. Thanks!
  • What room does this receptacle serve? – ThreePhaseEel Jan 26 at 23:15
  • Wire from top of bookcase into the wall.....if you wanted the outlet up the wall further, run a new line and install a new outet at the desired location. Or use an extension cord from the top location to the outlet. – Jeff Cates Jan 28 at 4:13
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
