My property has no LP gas currently. I am converting an out building and need heat in several of the rooms. Can I run a gas line along the horseshoe shaped inside wall that is a common wall to all the rooms and have 5 split offs from the main line in?
  • Hello, and welcome to Home Improvement. All we could answer would be "maybe", unless you add more info (e.g. a dimensioned diagram, with pipe sizes). – Daniel Griscom Jan 26 at 18:06
  • it is unclear what you are trying to ask .... of course you can run the gas line .... but, is that really what you want to know? – jsotola Jan 26 at 19:21
The flexible gas line is readily available to carry the gas. The critical point is that it is sized properly to carry the load. An under sized line will create a hazardous situation.
