Ok here we go. I got a little too confident and now I have no power. Originally I had no power to half my garage. The fuse was blown and when I would try to put a new one in it didn’t wanna go in. Like it was warped. So I decided to clean the contact. I pulled the big fuses in fuse box. (The ones that look like shotgun shells) to kill power and opened it up. It was full of crap and mud dabbed next so I cleaned them out then took apart the fuse holder and lightly sanded the contact and got the fuse to fit again. I put it all back together and this is when I messed up.
I decided it would be a good idea to blow out the box with air compressor. While doing so I stick my nozzle where I couldn’t see and BAM!!!!! It touched a wire I assume coming from the breaker and running into the box. It tripped one of the two breakers for garage with the lower off at the breaker I used a wire brush to clean up the charred wire. I did not take it apart though. Now I have no power at all to my garage. Well I have power cause if I put my tester near outlets it beeps but only on some the fuse that I shorted does not beep and none of the outlets beep. What did I do?
