I have a few lamps in the house that are now wifi control enabled. I use google home to control them. So far, I have been using wifi plugs - but the issue is that some guests who are not comfortable with google home are unable to control the lamps.
So, I want to install a physical override in parallel. Most of the examples I am seeing are for wall mountings. For a floor lamp, this is my plan: - Use the Sonoff wifi switch - House it in a plastic unit where at the top, I can install a push button or on/off switch
My question: - Anyone who has done this and can give me some inputs. - Any downsides to what I am proposing or a better way or better products to achieve this? - Is there a readymade product that is a closed module that has wifi and a physical switch together?
Thanks
