My wife and I moved into our new house today. I plugged my phone charger in tonight and the outlet sparked and my breaker tripped. I then plugged a different charger in and it didn't trip. I went to a different outlet (on the same circuit) and plugged the charger I suspected to be faulty in and it worked fine. I'm fairly electrically literate and this has me stumped. Any ideas?
    what kind of a breaker tripped? – jsotola Jan 24 '19 at 3:49
    Does the breaker that tripped have a TEST button on it? – ThreePhaseEel Jan 24 '19 at 4:49
    Turn off the breaker, pull out the receptacle and examine the wiring. Possibly there is simply a loose connection . . . or a neutral or ground is close to contacting a hot wire and does so when manipulated. If the current receptacle is "backwired" in the spring loaded contacts, switch the wires to the side contacts. – Jim Stewart Jan 24 '19 at 10:11
  • The breaker does not have a test button. I'm not sure what kind it is, its 200A breaker box, on a 15A circuit – Josh Jan 24 '19 at 13:10
