How can water be diverted away from the street curb in front of my house? Several of my neighbors are draining water from their sump pumps onto the road and it runs down the curb and collects in front of my house. Leaves and water are constantly filling up the curb in front of my property. The opposite side of the street is dry but there's always water sitting in the curb in front of my house, even days after it has stopped raining. It's frustrating to open my mail box and accidentally drop a piece of mail into the water. Also had to ask my newspaper delivery person to stop throwing the newspaper on my driveway since it's constantly wet from run off from the neighbor's sump pump. Would it help to spread gravel or rocks along the curb? I live in the city limits and there are sewer drains at various locations along the streets.
You really can't. I've had low spots in front of several homes. It's a pain especially where winter occurs. Unless you can get your municipality to rework the curbing to flow properly, work around it.– isherwoodJan 22, 2019 at 21:47
And don't put debris on the street. That would probably violate local statues and cause a hassle for the street maintenance department.– isherwoodJan 22, 2019 at 21:47
Unfortunately, our street is fairly flat and it doesn't slope enough to carry the water to the drain at the end of the street. I did see a picture of a gutter which can be used on the curb - are you familiar with those?– KathyJan 24, 2019 at 17:56
1 Answer
Sure you can get rid of the water, but it would take re-grading the street or adding additional pipes.
The street is in the right-of-way so you’ll need a permit and engineered drawings. We often take care of our clients roads, maintenance, etc., but it’s expensive once the City has screwed up the layout and paving.
You have a “low spot” that will need to be 1) raised, or 2) additional underground drainage added.
1) If there is adequate slope, a topping can be installed and re-contour the street so the water drains away. An engineer will need to survey the area and show the City how it could be done.
2) Additional pipes could be installed, but , again, an engineering company will need to show depth, slope of pipe, size of pipe, how to connect (and where) into existing storm pipe, etc.
Thanks for these suggestions. The curb has good size drop when driving off of my driveway onto the street - I've thought about filling it in with some cement to make it smoother and more even with the driveway. But I didn't want to do something unattractive..– KathyJan 24, 2019 at 18:03
@Kathy Don’t forget to get a permit from your City to work in the right-of-way. They’ll need to approve what you propose, or you could be liable for any accidents, etc.– Lee SamJan 24, 2019 at 18:25
