Tech lighting brand 300 watt monorail lighting system installed in 2010. For the last couple years we’ve had problems with intermittent lighting with one of the pendants on suspension cables. Jiggling worked for a short time. Now a second pendant (of three) is exhibiting the same issue. The first is not working at all the second is dim and the third is okay.
Can you provide any recommendation to fix the problems?
Thanks, M. Haycook
