I have 4 zone boiler/baseboard heat and a new Trane XR 5ton central A/C system. I also have a woodstove that is mainly used for heating except at night when the upstairs are closed. I just got the AC hooked back up to the master bed thermostat and the air handler fan did great moving the heat around upstairs. I don't want to leave it on all night though and it would be nice not to manually set it.
My Sensi Thermostat has: -Rc: 24VAC cooling -Rh: 24VAC? Heating for one zone -O/B: 24VAC Common from AC condenser board -Y: To AC power -W: To boiler zone solenoid -G: AC air handler Fan
-->Main question, can I jump W and G or could that cause some problems in the AC circuit? Do Rh and Rc need to be in phase? Would it blow a fuse if the Fan ON was set basically connecting Rh and Rc?
I guess I'll have to disconnect it when we actually start using the AC so it doesn't activate the heat.
Thanks, Ian
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
