I have a miter saw but that thing is loud. Same with the circular saw. Moreover, while the miter saw can be used on the ground with not even a table, the circular saw is too dangerous without a full workbench.
A table saw, even mini one, is too big, expensive, and also too loud. It needs to be handheld. Obviously, chainsaw is not the answer either.
Of course, the quietest is a simple hand saw. Unfortunately, it's also too much work and takes too long. I want something electric.
This brought me to the reciprocating saw. It could be used easily with a couple portable sawhorses or even just clamped to the table.
Handheld jigsaw might be the same.
For safety, of course awareness, alertness, glasses, earmuffs, gloves, and common sense will all be used. Still, some tools are less safe than others without a full workshop. I'm also thinking of building a small portable workbench.
I don't want to disturb the neighbors or cause any alerts with the apartment complex. So, what is the best, quietest, safest, and easiest electric saw to use to cut 2x4 without a full workshop or full work bench?
