Though it isn't specifically stated in the code, I try to protect cable that is installed less than 8 feet from the ground with conduit. This tends to be accepted by inspectors as "protection from physical damage."
If I am going straight up from the electrical panel, into garage rafters, I would like to use a conduit sleeve up to the 8ft mark and then continue on with bare cable. This means the conduit would create a path for critters/dust to enter the panel... is there something I can put over the end of the sleeve?
Thank you!
