Furnace: Lennox Pulse
Thermostat: Honeywell RTH6500WF
I have the similar setup as the person in the below link
Can I use the T terminal in my furnace as the C for a Wifi Thermostat?
When I connect the unused blue wire to T Terminal on furnace to C Terminal, then R to R with jumper to Rc on stat, Y to Y, G to G, W to W. Flip the breaker. Thermostat is not powered? The thermostat works because I had a backup plan to use a AC adapter and it worked fine.
What troubleshooting can I do with this issue. I have multimeter.
Thanks
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
