I'm not sure this is the right place to be asking this but I'll give it a try. I have this bit of hardware from a pair of helping hands that I'd like to find more of. I'd describe it as a rod fastener of some sort. Not having any luck with those search terms however. Perhaps someone here has the proper name. Thanks in advance.
1It's called throw-it-out-and-buy-a-new-one ... – brhans Jan 16 at 22:25
That is a non-standard part. You will not likely find an identical one. – bib Jan 16 at 23:16
you could make one out of this and a piece of a bolt .... homedepot.com/s/rod%2520coupling%2520nut?NCNI-5 – jsotola Jan 17 at 3:51
