Wiring in ceiling.1I'm trying to replace my kitchen ceiling light fixture but... coming out of the ceiling I have 3 black wires, 3 white wires, a red wire and a ground! I didn't take a picture of how they were wired before removing old fixture - yes, I know. The new fixture only has a black, a white, and a ground.Please help!! Thanks
    I assume that the question is "how do I connect the fixture?" We can't say. One of the black-white pairs could be a switch loop, but we can't know with what you've provided. You'll need to get your hands on a multimeter and do some investigation.
    Jan 16, 2019 at 14:56
    Did you only remove the wires going to the old fixture, or did you take them ALL apart? If the latter, can you shoot photos of what's in the lamp box and also the switch box? Don't unwire the switch also... Jan 16, 2019 at 16:37
  • Can you post photos of the insides of all the boxes? Jan 17, 2019 at 0:16
If your wiring is standard and NEC-compliant:
One cable is the feed, one is te line gouing to next lamp, the third (that has 4 wires: red, black, white and copper) is the wire from the switch.
Just connect whites together (the 4 from wall + one from the fixture), the blacks coming (from wall) together, and the black from the fixture to the red (from the switch)
If you're not sure / don't know how to check, hire an electrician to have it fixed
