I have a buddy building a new house and the guys that did the drywall didnt use green board in the bathrooms. We live in iowa. Is it code to put greenboard in the bathrooms in iowa i cant seem to find it if there is
    They are passing out green board now. There really isn't a place for it anymore. Jan 15 '19 at 4:19
  • Personally, I like the purple board for bathrooms in non-wet areas. Mold, fire, and moisture resistant. Wet areas require special attention (cement board and moisture barrier for example) Jun 14 '19 at 1:08
  • What part of the bathrooms? All walls or just some? Nov 11 '19 at 14:11
    Did you ever get this resolved? If so, please give a check-mark to the answer that helped you the most, or write up your own answer explaining what you did to get it fixed and give yourself a check mark. That will help others with this kind of problem know that this has a resolution and is a good place to look for their answer.
    Aug 8 '20 at 3:17
Yes most town's inspectors will require greenboard. As I have mentioned in other comments this is about 80% in 5-6 states. So more than likely it is a requirement.
And to clarify greenboard cannot be exposed in shower areas except for ceilings and above adult heights (6 feet). Maybe someone can find a real "rule" but this is what 30+ different inspectors have told me. So in most cases we have greenboard everywhere in bathroom except shower - unless it is a prebuilt fiberglass in which you have to have either greenboard or cement board (doesn't work on these well) behind - or nothing.
Does it do anything at all or server any purpose? In almost all cases no. It does offer a little bit more resistance but water is tricky. There are hardly any cases where you are right on the edge of having an issue. Either you messed up and have an issue or you don't. Greenboard might offer an extended period of no mold/water logging from extreme steam plus a poor paint job. But eventually it will fail exactly like regular "white" drywall and the mold and everything will be the same spots.
The key to a mold free, maintenance free bathroom is an oil based primer. You slap on two coats in a couple hours and it is basically a shell on the walls. Yes it stinks and yes it is toxic to a point but only until it dries. You can then do whatever you want on top (oil based paint or latex primer plus paint).
-1
In most places I have worked, the green board is only required on walls around tubs and showers, not the entire bathroom, and not if using a pre-fab tub or shower enclosure.
    Green board is not rated for use in a shower area.
    – Matthew
    Jan 15 '19 at 2:54
-1
The Code says bathroom finishes must be hard, smooth, non-absorbent, and not adversely affected by moisture, except in private dwelling units. (See ICC 1210.2.2)
Showers shall be smooth and non-absorbent up to 70” above the drain, if a shower head is installed. (ICC 1210.2.3)
    For clarity, this addresses the finish when complete. It doesn't say (or even imply) that drywall must have special treatment.
    Nov 11 '19 at 13:48
-1
It's usually not required (some areas have legacy rules that are yet to be corrected), and in my opinion it's pointless. If enough water gets through your paint that you're depending on the drywall for containment you have bigger issues. Good quality primer and paint accomplish the same thing, and if you're installing tile you probably want cementboard anyway.
I'm not surprised that the rule is on the books in some places yet. They haven't gotten around to correcting their folly.
I'll be leaving this answer up despite the downvotes. Until someone does a survey of all US jurisdictions there's no evidence that I'm wrong. Votes should not reflect anecdotal opinions.
