I'm used to pait cans where the lid can be simply pried off using a screwdriver. However this one seems different:
How do I open it?
There are no instructions on the can itself.
I did some poking and was able to break and remove the silver ring with needle-nose pliers. The lid beneath can now be pried open with a screw driver.
| improve this answer | |
  • Hello, and welcome to Home Improvement. Thanks for answering your own question, but you now have two separate accounts. You should use the Contact form to request that your accounts be merged. And, keep your posts coming! – Daniel Griscom Jan 13 '19 at 19:48
If that is a plastic top it likely has to have the overhanging lip flexed out off a ridge on the top outside edge of the bucket.
This looks like it could be the full transition from metal paint cans to all plastic. For a while now paint cans have been a hybrid with plastic bucket but still with the crimped on metal top rim that accepts the old familiar metal paint can cover.
