Two receptacles and a sconce -- all sharing a wall -- stopped working the other day. I took everything apart looking for loose connections and found the following:
  • The two receptacles only have one pair of wires coming in; the sconce has two pairs coming in and one going out.
  • When connecting a voltage meter to the black bundle in the sconce and the ground bundle (or box), the circuit completes, but connecting the meter to the black bundle and white bundle, the circuit does not complete.
  • I can't see any obvious crossed wires or anything else amiss.
Any thoughts of where I should go from here? Is the problem likely to be in this box or somewhere else between here and the breaker?
Four wires enter the box from the top (old sheathing); two exit from the bottom (new / rubber white + black sheathing) Description: Four wires enter the box from the top (old sheathing); two exit from the bottom (new / rubber white + black sheathing). White bundle at top; black bundle at lower left; ground is inside box at right side, soldered to box. Circuit completes (only) when connecting black bundle to ground.
Update: If I touch the white bundle in this box to the ground, both of the downstream receptacles work, as I expected, but as per this answer, that seems like a dangerous and unsatisfactory solution.
Update 2: There's another sconce and another receptacle that work correctly (without crossing ground and neutral in the faulty one). It's hard for me to understand how both legs of these seem to be functional while the other three devices have some problem in the neutral line. Perhaps the ground and neutral are crossed in one of the two functioning devices?
  • Dsee how in each bundle, one wire is more dingy than the others? Take a nail file to the end of it to polish it up. Does it turn copper-orange or gray-silver? Jan 12, 2019 at 17:23
  • @Harper they're all copper as far as I can tell.
    – nvioli
    Jan 12, 2019 at 17:54
From your description, I'd say one set of old wires in the box was the feed from the power source, and the other set of old wires feeds to other loads downstream. The newer cable probably feeds the receptacle. Just a guess though.
It's definitely NOT a viable solution - it wasn't really even safe as a test. However it does indicate the problem is likely due to a neutral connection or break in the wire between this box and the source.
Tracing this back and finding the problem may be easy or may be very difficult.
